Agilex 7 i series U-boot Procedure
Iam currently using the Intel Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit with the device number AGIB027R31B1E1V (DK-SI-AGI027FA).
The provided link is specifically for the I-Series board: AgilexSoCGSRDSIAGI027.
I would like guidance on creating the U-Boot process and debugging U-Boot using ARM DS for this particular kit.
Thanking You....!
- Jeet14
You can refer the procedure given on rocketboard for your board AGIB027R31B1E1V (DK-SI-AGI027FA).
For debugging u-boot from Arm Eclipse, refer below link.
Tiwari
- HPS
Hi Tiwari
Thank you for your reference.
we have alredy follwed the procedure in the link but during the make process it throws error as below.
“Image 'u-boot' is missing external blobs and is non-functional: blob-ext
/binman/u-boot/fit/images/atf/blob-ext (bl31.bin):
Missing blob
Some images are invalid”
Do you have any idea about the above issue.please reply ASAP.
- Jeet14
It looks like files are not generated properly or workspace path is not correct.
Can you re-try the steps from the scratch?
Tiwari
- Jeet14
Please let me know if you have any question on this?
Tiwari
- Jeet14
