EricOpitz
1 year agoAgilex 5 QSPI Probe fails
Dear all, I'm working on getting RSU running on the Agilex 5 Arrow AXE5-Eagle dev kit. My problem regards the new version QPDS25.1. With this version I can not probe the QSPI flash. Using the...
- 1 year ago
Hi Eric
In 25.1 a new feature was introduced to control if you want to allow or prevent to grant the ownership of the QSPI to the HPS.
https://cdrdv2-public.intel.com/853092/ug-813762-853092.pdf
See section 4.2.1 and 4.12.
Check in your hardware design if the QSPI ownership is assigned to the HPS. If this is not the case, then the SDM will reject the MBOX_QSPI_DIRECT mailbox.
Rolando
EricOpitz
1 year agoHi Rolando,
This solves the problem. Thank you for your Help!
Kind Regards,
Eric Opitz
