Agilex 5 QSPI Probe fails
- 1 year ago
Hi Eric
In 25.1 a new feature was introduced to control if you want to allow or prevent to grant the ownership of the QSPI to the HPS.
https://cdrdv2-public.intel.com/853092/ug-813762-853092.pdf
See section 4.2.1 and 4.12.
Check in your hardware design if the QSPI ownership is assigned to the HPS. If this is not the case, then the SDM will reject the MBOX_QSPI_DIRECT mailbox.
Rolando
Hi Eric
Could you please share the latest boot log that you are facing?
Did you replace the device tree and the linux image generated using the 25.1 flow?
I believe the Quartus Version you are using is still 24.3, but I think it is able to run with the 25.1 linux binaries.
Did you make the same changes done to the uboot device tree with the linux device tree?
Jingyang, Teh
