Agilex 5 GTS to HPS CDC/STA issue: help request!
Have you tried to configure the bitstream ("Full Test") via JTAG or at boot prompt (fpga load)?
What Quartus Pro version and u-boot/linux branch versions are you using? Thanks.
Stefan
Hi - unfortunately with JTAG programming, this error occurs:
... Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1... Loading Environment from UBI... "Synchronous Abort" handler, esr 0x96000010, far 0x108d2000 elr: 0000000080263ce8 lr : 0000000080263ef4 (reloc) elr: 00000000ffd54ce8 lr : 00000000ffd54ef4 x0 : 00000000108d2000 x1 : 0000000000003228 ... Code: 32000021 d5033fbf b9000001 d65f03c0 (b9400001) Resetting CPU ... ### ERROR ### Please RESET the board ###
Here the u-boot and linux branches are:
git clone -b atuma5_v1.1 https://github.com/terasic/u-boot-socfpga u-boot-socfpga git clone --filter=tree:0 -b atuma5_v1.2 https://github.com/terasic/linux-socfpga linux-socfpga
It is worth also noting, that:
1: It seems doing it this way does let the bitstream load onto the FPGA (based on LED responses)
2: Doing it this way with a base HPS bitstream (with no GTS component) lets the boot sequence finish successfully
- StefanG_Altera1 year ago
Ok I understand the "full test" image also failed to configure over JTAG but we lack more detailed information why.
Can you please confirm the Quartus version you use?
I assume you are using the HPs 1st mode configuration, please confirm.
In this case can you stop at u-boot prompt and manually run fpga load, e.g. according to the u-boot bootcmd (CONFIG_BOOTCOMMAND environment example) in https://altera-fpga.github.io/rel-25.1/embedded-designs/agilex-5/e-series/modular/boot-examples/ug-linux-boot-agx5e-modular/#boot-from-sd-cardCONFIG_BOOTCOMMAND="load mmc 0:1 \${loadaddr} ghrd.core.rbf; fpga load 0 \${loadaddr} \${filesize};bridge enable;..
In case of failure it should report an error code and related details, see an example capture below:
Stefan- K6061 year ago
Contributor
It is Quartus 24.3. Yes it is in HPS First mode.
When executing the command you mentioned, I get this result:
SOCFPGA_AGILEX5 # fpga load 0 ${fpgadata} ${fpgadatasize} .............................................................FPGA reconfiguration failed! Command 'load' failed: Error -110- StefanG_Altera1 year ago
Could you try "bridge disable" before "fpga load" at u-boot prompt?
My understanding is that the configuration error reporting feature is incorporated in v25.1 embedded SW package (need to confirm).
Could you try to compile your FPGA design (GHRD) with Quartus Pro 25.1 and build u-boot from our v25.1 fork?
git clone -b QPDS25.1_REL_GSRD_PR https://github.com/altera-fpga/u-boot-socfpga
As in the Agilex 5 Premium Development Kit Example in https://altera-fpga.github.io/rel-25.1/embedded-designs/agilex-5/e-series/premium/boot-examples/ug-linux-boot-agx5e-premium/#boot-from-sd-card
You would need to include your defconfig (configs/socfpga_agilex5_atuma5_defconfig, include/configs/socfpga_agilex5_atuma5.h) and device trees in arch/arm/dts (socfpga_agilex5_atuma5.dts, socfpga_agilex5_atuma5-u-boot.dtsi).
Stefan
