Agilex 5 GTS to HPS CDC/STA issue: help request!
Have you tried to configure the bitstream ("Full Test") via JTAG or at boot prompt (fpga load)?
What Quartus Pro version and u-boot/linux branch versions are you using? Thanks.
Stefan
- K60611 months ago
Contributor
Hi - unfortunately with JTAG programming, this error occurs:
... Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1... Loading Environment from UBI... "Synchronous Abort" handler, esr 0x96000010, far 0x108d2000 elr: 0000000080263ce8 lr : 0000000080263ef4 (reloc) elr: 00000000ffd54ce8 lr : 00000000ffd54ef4 x0 : 00000000108d2000 x1 : 0000000000003228 ... Code: 32000021 d5033fbf b9000001 d65f03c0 (b9400001) Resetting CPU ... ### ERROR ### Please RESET the board ###Here the u-boot and linux branches are:
git clone -b atuma5_v1.1 https://github.com/terasic/u-boot-socfpga u-boot-socfpga git clone --filter=tree:0 -b atuma5_v1.2 https://github.com/terasic/linux-socfpga linux-socfpgaIt is worth also noting, that:
1: It seems doing it this way does let the bitstream load onto the FPGA (based on LED responses)
2: Doing it this way with a base HPS bitstream (with no GTS component) lets the boot sequence finish successfully
- StefanG_Altera11 months ago
Ok I understand the "full test" image also failed to configure over JTAG but we lack more detailed information why.
Can you please confirm the Quartus version you use?
I assume you are using the HPs 1st mode configuration, please confirm.
In this case can you stop at u-boot prompt and manually run fpga load, e.g. according to the u-boot bootcmd (CONFIG_BOOTCOMMAND environment example) in https://altera-fpga.github.io/rel-25.1/embedded-designs/agilex-5/e-series/modular/boot-examples/ug-linux-boot-agx5e-modular/#boot-from-sd-cardCONFIG_BOOTCOMMAND="load mmc 0:1 \${loadaddr} ghrd.core.rbf; fpga load 0 \${loadaddr} \${filesize};bridge enable;..
In case of failure it should report an error code and related details, see an example capture below:
Stefan- K60611 months ago
Contributor
It is Quartus 24.3. Yes it is in HPS First mode.
When executing the command you mentioned, I get this result:
SOCFPGA_AGILEX5 # fpga load 0 ${fpgadata} ${fpgadatasize} .............................................................FPGA reconfiguration failed! Command 'load' failed: Error -110
