5CSXFC2C6U23C8N_pinout
For PN"5CSXFC2C6U23C8N" Pin named"HPS_TRST" have a description as an active low pin, however, name doesn't have any letter indicated that like"HPS_nRST", which have letter n for that. can please confirm " is this pin"HPS_TRST" is active low and what letter should added in symbol for indicate that ?
- FvM
TRST is a well defined JTAG boundary scan signal, the only useful connection is to a JTAG programming adapter that supports it. USB Blaster doesn't use TRST, but if you are providing an interface for a full featured ARM debugger with trace functionality, you would connect it to the respective debug connector.
Official signal name according to JTAG IEEE Std. 1149 is TRST* to indicate active low operation. Because asterix is no legal symbol in many EDA systems, it's often omitted. nTRST would be a possible alternative, but it can cause confusion. I'd stay with TRST, keeping in mind that it's inverted. PCG document is clear about inverted function, in so far there's nothing to clarify, I believe.Regards
Frank
- SueC_Altera
Contributor
Great answer, Frank!
- BoonBengT_Altera
Moderator
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
- BoonBengT_Altera
Moderator
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome.
Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
