Xcelium Simulation of Agile5 design FATAL when entering Simulation?
Still not solved, but I did run the canned xcelium_setup.sh created in our Platform Designer block in the QSYS_DIR/sim/xcelium_setup.sh. When running this script I modified it to show me the commands which are being executed for xmelab and xmsim. I do not see the switch "-sv_lib" set in this conditions and the simulation runs to completion.
So this is the actual FPGA design which is not instantiated with our Testbench and DUT. The one difference that I notice is that there is a "libdpi.so" in this directory so it is just picking up this default name and location. Our environment is a little more complex because we also do incremental compile for the design as the various DUT pieces take quite some time.
So I am still a little baffled given that I am able to run the UNIT simulation created by QUARTUS for our FPGA and it runs fine with any additional switches.
Any thoughts?
TomT...
