14 years ago --- Quote Start --- I thought that when used as a component virtual pins would work, since I don't really need the pins, it's just a signal. There is some way I could have a component with lets say 2000 in/out? --- Quote End --- No. Not even the biggest most expensive devices have that many IO pins! You will have to look into some data transport protocall to get data in or out of your system (like ethernet, or serial).
