18 years agoWriting data to output file VHDL
Hi all,
I'm working with a DE2 Altera board Quartus II 6.1 and am trying to take data that I receive from the board, and send it to an output file, a text file. There will be a lot of data so I don't want to use the output LEDs or LCD. I found this simple code online, but it will not compile on my machine b/c I get the following error: Error (10481): VHDL Use Clause error at printing.vhd(5): design library "IEEE" does not contain primary unit "std_logic_textio" Does anyone know how I can perform a simple output to file???? library STD; -- you don't need STD, it is automatic library IEEE; -- but may need other libraries use IEEE.std_logic_1164.all; -- basic logic types use STD.textio.all; -- basic I/O use IEEE.std_logic_textio.all; -- I/O for logic types ENTITY printing IS port ( abc :in std_logic ); END printing; architecture test of printing is -- where declarations are placed subtype word_32 is std_logic_vector(31 downto 0); -- simple name signal four_32 : word_32 := x"00000004"; -- just four in hex signal counter : integer := 1; -- initialized counter begin -- where parallel code is placed my_print : process is -- a process is parallel variable my_line : line; -- type 'line' comes from textio begin write(my_line, string'("Hello World")); -- formatting writeline(output, my_line); -- write to "output" write(my_line, string'("four_32 = ")); -- formatting hwrite(my_line, four_32); -- format type std_logic_vector as hex write(my_line, string'(" counter= ")); write(my_line, counter); -- format 'counter' as integer write(my_line, string'(" at time ")); write(my_line, now); -- format time writeline(output, my_line); -- write to display wait; end process my_print; end architecture test; -- compile/analyze this file Thanks Paul
