18 years agoYou are mentioning a DE2 Altera board. Are you trying to do this on hardware or is it a test bench simulation?
What simulator are you using? I know that the ieee.std_logic_textio package is included i ModelSim. I don't know about NCsim and simulation inside Quartus. You might need to install/map additional libraries and packages. For hardware, the textio packages are simply not synthezisable. What kind of interface is it from the board to where you are trying to write a file?
