15 years ago --- Quote Start --- Yes - that is what I meant. Any other things I should check? --- Quote End --- Hi, what misbehaviour shows your design running of the FPGA ? Look into your reports of the main Quartus project. Look for strange messages ( e.g Latches, Pins stuck ground .... ) and timing violations. Which simulation do you use ? Kind regards GPK
