15 years ago --- Quote Start --- Yes,you are right. I simulated each part separately - and they worked in simulation. I'm now simulating the entire project (it takes some time) I also tested the non Synplify related stuff - and they work too . I have a question - when I update my qxp files - what do I have to do to update them in the main project? What I do now is the following: I delete the "imported partitions" folder in the project library, I then overwrite the old qxp files. In quartus I select all the partitions - right click - import, and I press ok (when "reimport using latest files from previous location" is selected). Is this correct? --- Quote End --- Hi, unfortunately I don't have the old Quartus Version available. "Overwrite the old qxp file" means you are running the speparate Quartus project again and after that you export the design as design partition again ? If yes, it should be ok. Kind regards GPK
