15 years agoYes,you are right.
I simulated each part separately - and they worked in simulation. I'm now simulating the entire project (it takes some time) I also tested the non Synplify related stuff - and they work too . I have a question - when I update my qxp files - what do I have to do to update them in the main project? What I do now is the following: I delete the "imported partitions" folder in the project library, I then overwrite the old qxp files. In quartus I select all the partitions - right click - import, and I press ok (when "reimport using latest files from previous location" is selected). Is this correct?
