15 years ago --- Quote Start --- What output are you referring to? I used the Verilog implementation, which I converted to VQM, which I then exported as a post synthesis design partition, which I then imported into my main project. Compiled it and loaded to the FPGA. Simulation I did in Quartus on the "vqm stage". --- Quote End --- Hi, that means you are running the simulation with the SynplifyPro VQM File. But as far as I understand this only a part of your design. Right ? Kind regards GPK
