16 years agoThis is another example codings we've written:
module testing_wed2 (data_in, data_out); input [7:0] data_in; output wire [3:0] data_out; reg lsb_enable; wire msb_enable; always@* begin if(data_in) lsb_enable <= 1; else lsb_enable <= 0; end lsbmo lsbmo_controller_block_unit (.data_inl(data_in), .lsb_enable(lsb_enable), .msb_enable(msb_enable), .data_outl(data_out)); msb msb_controller_block_unit (.data_inm(data_in), .msb_enable(msb_enable), .data_outm(data_out)); endmodule
