16 years agomodule fifo
# (parameter B=8, W=4) (clk, reset, read, write, write_data, read_data, empty, full); input clk, reset, read, write; input wire [B-1:0] write_data; output empty, full; output wire [B-1:0] read_data; // signal declaration reg [B-1:0] array_reg [2**W-1:0]; reg [W-1:0] write_reg, write_next, write_done; reg [W-1:0] read_reg, read_next, read_done; reg full_reg, empty_reg, full_next, empty_next; wire write_enable; // body // register file write operation always @(posedge clk) if (write_enable) array_reg[write_reg] <= write_data; // register file read operation assign read_data = array_reg[read_reg]; // write enabled only when FIFO is not full assign write_enable = write & ~full_reg; // fifo control logic // register for read and write pointers always @(posedge clk, posedge reset) if (reset) begin write_reg <= 0; read_reg <= 0; full_reg <= 1'b0; empty_reg <= 1'b1; end else begin write_reg <= write_next; read_reg <= read_next; full_reg <= full_next; empty_reg <= empty_next; end // next-state logic for read and write pointers always @* begin // successive pointer values write_done = write_reg + 1; read_done = read_reg + 1; // default: keep old values write_next = write_reg; read_next = read_reg; full_next = full_reg; empty_next = empty_reg; case ({write, read}) //2'b00: no options 2'b01: // read if (~empty_reg) begin read_next = read_done; full_next = 0; if (read_done==write_reg) empty_next = 1; end 2'b10: // write if (~full_reg) begin write_next = write_done; empty_next = 0; if (write_done==read_reg) full_next = 1; end 2'b11: //read and write begin write_next= write_done; read_next = read_done; end endcase end // output assign full = full_reg; assign empty = empty_reg; endmodule
