16 years agoRF frequency 433.92 MHz
Modulation: FSK I'm connecting the 4 data pins of the decoder at the receiver side to 4 LEDs. this is the code for receiver side: module receive_testing # (parameter W_SIZE = 2) // 2^W_SIZE word in FIFO (clk, reset, from_expansion, LED); input clk, reset; input [3:0] from_expansion; output wire [7:0] LED; reg write_code; wire full_code, read_code; reg [7:0] data_out_reg; wire write_enable, write_disable; wire [7:0] data_out_next; fifo# (.B(8), .W(W_SIZE)) fifo_block_unit (.clk(clk), .reset(reset), .write(write_code), .read(read_code), .write_data(from_expansion), .read_data(data_out_next), .empty(write_enable), .full()); always @(posedge clk) if (reset) data_out_reg = 0; else data_out_reg <= data_out_next; always@* begin if(from_expansion) write_code <= 1; else write_code <= 0; end assign LED = data_out_reg; assign read_code = ~write_code; endmodule
