16 years ago --- Quote Start --- Hi, We are experiencing a problem with Quartus 9.1 and SIgnalTap. I've search the forum and found nothing similar. When we do SignalTap plus place&route on our 64-bits linux server, the generated assembler file works fine in the programmer on a Windows machine and the design is functional. But SignalTap is not recognizing his target like when you put a incoherent programming file and signaltap definition. It seems there is something wrong between a SignalTap fit generated on a 64-bits Linux and SignalTap on a 32-bits Windows PC. Have you experienced such a thing ? EME --- Quote End --- Hi, what kind of error message did you get ? Kind regards GPK
