--- Quote Start ---
Does anyone know how to install a USB "Software Guard" under Windows 7 x32?
I tried installing it using the quartus driver directory, and now whenever I plug the software guard in and if finds what it thinks is the appropriate driver... BSOD.
So... any help would be more than helpful.
Mast3rL33
--- Quote End ---
I did nothing to install it, just looked in the device manager and the dongle was happy as a clam under Win7-64. But, while the Quartus license tool finds the dongle and lists its ID, the enumeration of the licensed functions never completes. Infinite hourglass. Running under the 30-day key to test. Other than that, Q2 seems to work fine under Win7-64.
I must admit, though, that I haven't tried the USB Blaster yet -- my real work is still on the XP machine.
Edit: Ummm never mind. Wrong license file. USB dongle and license server all happy. USB-Blaster not so much
Edit again: USB Blaster install needs to have signed driver check bypassed. Win 7, as normally installed, mandates driver signing and does not explain why the USB Blaster driver install is failing. Changing the OS config to ask if an unsigned driver is OK allows the install to proceed.
