--- Quote Start ---
From what I gather from
altera.com, software guard is supported under Vista, so it should work under 7. However, since QII V8.0 software guards aren't supported anymore and I don't think QII versions smaller V8.0 will be supported under 7, so I guess you should try to get a NIC license or floating license from Altera support instead. Or is the dongle a lifetime license?
--- Quote End ---
Where did you read that usb software dongles are no longer supported? We use them all over the place at the company I work for.. I've been using it with QII v9 for a while now, and am just about to move up to QII 10.1 SP1 with my new Win7 laptop...
--- Quote Start ---
hello there,
can anybody confirm that now USB Blaster works with win7 64 bit ? (with out turning off signed driver check)
--- Quote End ---
--- Quote Start ---
Yes, it works.
Jari
--- Quote End ---
So QII 10.0 (SP1), USB Blaster (both Altera and Terasic), and USB Software License Dongle... all work with both Win7 x32bit and Win7 x64bit?
Is there a recommended procedure to follow?
cheers,
..dane
