Why won't the altera floating point add sub ip synthesize?
- 6 years ago
Turns out the design won't synthesize because I am using the free web edition of Quartus 19.1, while this IP is only available in the standard and pro editions. This is a bit confusing considering I am still prompted with the option to add Altera Floating Point IP. What makes this even more frustrating that I was only able to discover this after searching through the Floating point IP core documentation which itself isn't immediately available unless you go searching for it online.
