Ruturaj_D_Intel
7 years agoWhy transceiver links are not detected in Transceiver Toolkit?
I am using Arria 10 device and Quartus Prime Pro version 17.0. In order to tune and check quality of Transceiver links in my design I am using transceiver toolkit and followed the steps given in the...
CheepinC_altera
7 years agoHi Ruturaj,
Thanks for your update. By merely looking at the “Input clock is running, reset is not asserted” message, I believe it is indicating that clock is present and reset is OK. Which indirectly indicate that the channels should be in user mode.
Based on the current observation, I am unable to tell what might be the problem on your side. I would recommend you to try out the example design from wiki. Alternatively, you may try to create a simple one channel test design mimic the example design if you have concern running the example design.
Chee Pin
