Ruturaj_D_Intel
7 years agoWhy transceiver links are not detected in Transceiver Toolkit?
I am using Arria 10 device and Quartus Prime Pro version 17.0. In order to tune and check quality of Transceiver links in my design I am using transceiver toolkit and followed the steps given in the...
CheepinC_altera
7 years agoHi Ruturaj,
Just would like to follow up with you on this.
Chee Pin
- Ruturaj_D_Intel7 years ago
Hi Chee Pin, Thank you for pointing to example design. I did take a look at the example design and could compile it, but I do not think I will be able to test example design on board we have. I am not sure if it is safe to test on the board. After studying example design I added in-system probes and debug IP in my design to control reconfig_reset and reset of XCVR link. Reconfig_clk is free running clock of 100 MHz. But even after these modifications and controlling reset from in-system sources and probes editor XCVR toolkit still does not populate XCVR links. I still see the message “Input clock is running, reset is not asserted”; I would like to know what this message mean? I am not sure if I am missing any step. In my design x1 XCVR channel is instantiated 4 times and I do not configure native phy as x4 link directly, due to this even though design has x4 links system console only shows 1 link as shown in the uploaded snap shot. Thanks, Ruturaj.
