Ruturaj_D_Intel
7 years agoWhy transceiver links are not detected in Transceiver Toolkit?
I am using Arria 10 device and Quartus Prime Pro version 17.0. In order to tune and check quality of Transceiver links in my design I am using transceiver toolkit and followed the steps given in the...
CheepinC_altera
7 years agoHi Ruturaj,
As I understand it, you have some inquiries related to using XCVR toolkit in A10 devices. In your observation, seems like the channels are not auto-populated. Would you mind to try with the following simple 1 channel design example from wiki which was previously verified working on an A10 devkit to see if it works for you? You may need to change the device, clock and XCVR frequency/pinout according to your board.
https://fpgawiki.intel.com/wiki/Arria10_Transceiver_PHY_Basic_Design_Examples#Arria_10_Native_PHY_with_Transceiver_Toolkit_design_example
Chee Pin
