Altera_ForumHonored Contributor16 years agoWhy TimeQuest add clock constrain automatically? I am studing using TimeQuest now. When I follow the "TimeQuest Analyzer Quick Start Tutorial" instruction, Analysis & Synthesis a project, then open TimeQuest, created a post-map timing netlist, next...Show More
Altera_ForumHonored Contributor16 years agoYes, you are right. What I should do is create a new .sdc and add my constrains. Thanks!
Recent DiscussionsConnection bit order between hierarchyFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)
