11 years agoWhy Quartus doesn't put the IP files into a independent folder?
I use Quartus IP catalog to generate some IPs. I found since you assigned the directory where the IP should be generated, Quartus just generate all the files of the IP into the directory, it doesn't create a folder which is named by IP's name. Since there are bunch of files generated with the IP, this will be very annoying if all the files of different IPs are put in a same folder. Is therr any approach to configure the Quartus to generate each IP files in their own folder?
Thanks in advance.
