SZack
6 years agoWhy is Signal Probe not supported for Arria 10 in Quartus Standard?
All other product families supported by Quartus Standard can use Signal Probe. Also the 18.1 Quartus Standard User Guide says "The Signal Probe feature supports the Arria series, Cyclone series, MAX...
KennyT_altera
6 years agoDepending on what requirement you have. you can look into the https://www.intel.com/content/www/us/en/programmable/documentation/spj1513986956763.html -> 1.1. Selecting an Intel Quartus Prime Software Edition
However, as mention, the engineering will focus most of the development now in pro ediiton. Unless the issue is critical, the engineering will not prioritize on that.
For the documentation, are you referring to the https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii53008.pdf. Let me know if I got the incorrect link.
SZack
6 years agoThanks Kenny. This is certainly not a critical issue. Cleaning up the documentation will at least avoid a customer wondering why it doesn’t work.
