SZack
6 years agoWhy is Signal Probe not supported for Arria 10 in Quartus Standard?
All other product families supported by Quartus Standard can use Signal Probe. Also the 18.1 Quartus Standard User Guide says "The Signal Probe feature supports the Arria series, Cyclone series, MAX...
sstrell
6 years agoAre we talking about the same thing? SP in Pro is the same (incremental routing through Rapid Recompile) except that there's currently no GUI (no Signal Probe IP):
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-debug.pdf
As for SP with A10 in Standard, yes, probably the document should make it clear.
#iwork4intel
- SZack6 years ago
In Standard, there was a simple GUI where you specified what signal(s) you wanted routed out to a pin and then what pin(s) to connect them to. That interface is gone in Pro.
