8 years agoWhy is my inout signal converted to output by eda netlist writer?
My simple test dut consists of the following code. When I run a compile on this code (Processing ->start Compilation) the netlist written by the EDA Netlist Writer has signal defined as output inste...
8 years ago --- Quote Start --- I tried compiling Altera's bidirectional port example I find that the results are not consistent, The first compile results in a netlist with an inout port, the second compile results in a netlist with an output port. All I had to do is click Processing->StartCompilation twice to get these two results https://www.altera.com/support/support-resources/design-examples/design-software/verilog/ver_bidirec.html --- Quote End --- I have attached the two netlists generated using the above process. Observe the content of the /simulation/modelsim/bidirec.vo grep -a2 "^output" */simulation/modelsim/bidirec.vo inout/simulation/modelsim/bidirec.vo-input clk; inout/simulation/modelsim/bidirec.vo-input [7:0] inp; inout/simulation/modelsim/bidirec.vo:output [7:0] outp; inout/simulation/modelsim/bidirec.vo-inout [7:0] bidir; inout/simulation/modelsim/bidirec.vo- -- output/simulation/modelsim/bidirec.vo-input clk; output/simulation/modelsim/bidirec.vo-input [7:0] inp; output/simulation/modelsim/bidirec.vo:output [7:0] outp; output/simulation/modelsim/bidirec.vo:output [7:0] bidir;
