8 years agoWhy is my inout signal converted to output by eda netlist writer?
My simple test dut consists of the following code. When I run a compile on this code (Processing ->start Compilation) the netlist written by the EDA Netlist Writer has signal defined as output inste...
8 years ago --- Quote Start --- Have you checked your design with the RTL Viewers and Netlist viewers? This will give you an idea how the logic/pin was implemented in the FPGA. --- Quote End --- I tried compiling Altera's bidirectional port example I find that the results are not consistent, The first compile results in a netlist with an inout port, the second compile results in a netlist with an output port. All I had to do is click Processing->StartCompilation twice to get these two results https://www.altera.com/support/support-resources/design-examples/design-software/verilog/ver_bidirec.html
