14 years ago --- Quote Start --- I want know why j>=0 is wrong at verilog? --- Quote End --- It's not wrong with Verilog. But loop evaluation fails according to your signal definition reg [3:0] i,j; Verilog numbers are unsigned by default, so j>=0 is always true. Iteration schemes are evaluated at compile time, there is no need to define loop variables as bit vectors. Use an integer type instead. Assigning dataout_memo in a loop prevents it's implementation as internal RAM. I'm not sure if this is what you intend.
