13 years agoThe component instance can be linked to the process by signals, not variables. Variables are only defined inside a process.
At second sight, I noticed several violations of VHDL synatax/semantic rules - while constructs aren't supported for synthesizable VHDL - you can't connect multiple output ports to the same signal
