SDmel
7 years agoWhy does SignalTap II Logic Analyzer display 'Program the device to continue' message even though the design was compiled with the latest SignalTap II file(.stp)?
Tool used: Quartus prime pro edition 18.0
SDmel
7 years agoBoth methods I tried still I am getting same error message
AnandRaj_S_Intel
7 years agoHi,
Can you see the size difference in sof file before and after adding the stp file?
Have you enabled Signal-Tap Logic analyzer under setting?
Can you delete the db, increment db, signal-tap and sof files.
And recompile the design and create new signal tap with minimum signals and check.
Anand
