13 years agoJTAG typicaly operates at 8 or 24MHz on Altera boards so factor in overhead that doesn't leave much bandwidth to sample in realtime. Normally if you need real time capture of data you use an external logic analyzer which is capable of keeping up with the data rate. Pumping that much data continuosly over JTAG makes about as much sense as draining a pool using a milkshake straw :)
