John
7 years agoWhy do I get this Synthesis error?
I am building a variant of a working project, using Quartus Prime Lite. It fails Analysis & Synthesis right at the end (97%). I have tried in V17.1.0 and 18.1, same error with both. It occurred af...
- 7 years ago
Does your project use any DCFIFO IP blocks, If so delete the component, create a new instance and try building it again.
JOHI
Contributor
7 years agoHello,
Sometimes you need to clean your project + delete all generated files before recompiling.
A mixup can occur where the quartus menu command "project/clean" is an option or even manually delete automatically generated subdirectories.
(I had it before that the output of 2 qsys generations with small modifications between 2 versions mixed things up. Cleaning things up got me back on track.)
Johi.
