BAdam1's avatar
BAdam1
7 years ago
Why do all registers return 0 when simulating the dual boot IP core in a MAX10 device.
I am trying to verify the functionality of the dual boot IP core in a MAX10 device. I issue a write to set bit 3 of offset 2 (See page 60 of ug_m10_config.pdf) The strange thing about this Write is that the response from the Avalon Packet interface indicates a successful write of 3 bytes not 4 bytes. I then Read offset 7 and it reads 0. I then write a '1' to offset 1 bit 1 to change the CONFIG_SEL value in the input register. I then check offset 3 to make sure that the core is not Busy. After that, I write to bit 3 of offset 2 again to trigger a read of the input register. When I read offset 7 again, it remains unchanged. It is still 0. I have tried Big Endian and Little Endian. Is there a problem simulating this core? Does it only work on an actual device?
  • BAdam1's avatar
    BAdam1
    I am trying to verify the functionality of the dual boot IP core in a MAX10 device. I issue a write to set bit 3 of offset 2 (See page 60 of ug_m10_config.pdf) The strange thing about this Write is that the response from the Avalon Packet interface indicates a successful write of 3 bytes not 4 bytes. I then Read offset 7 and it reads 0. I then write a '1' to offset 1 bit 1 to change the CONFIG_SEL value in the input register. I then check offset 3 to make sure that the core is not Busy. After that, I write to bit 3 of offset 2 again to trigger a read of the input register. When I read offset 7 again, it remains unchanged. It is still 0. I have tried Big Endian and Little Endian. Is there a problem simulating this core? Does it only work on an actual device? Bill Adams
  • BAdam1's avatar
    BAdam1
    I also have the On-Chip Flash Intel FPGA IP core in this design. I am able to access the Control and Status registers with no problem. I have been able to simulate, read, write and erase. Bill Adams
  • ShafiqY_Intel's avatar
    ShafiqY_Intel
    Here are you answer:
    I issue a write to set bit 3 of offset 2 (See page 60 of ug_m10_config.pdf)The strange thing about this Write is that the response from the Avalon Packet interface indicates a successful write of 3 bytes not 4 bytes. I then Read offset 7 and it reads 0.
    You need to trigger CONFIG_SEL_OVERWRITE (offset 1, bit 0) and CONFIG_SEL (offset 1, bit 1) if you want to make a change to the CONFIG_SEL (offset 7, bit 1) value.
    I then write a '1' to offset 1 bit 1 to change the CONFIG_SEL value in the input register. …….. When I read offset 7 again, it remains unchanged. It is still 0.
    If you want to change the CONFIG_SEL (offset 7, bit 1) value, you need to write 1 to CONFIG_SEL_OVERWRITE.
    For example, if you want to load from image 1, you need to write a ‘1’ to bit 0(offset 1) and bit 1(offset 1). You should write b’211 to offset 1.
    Then, if you want to read back the value, you need to write a ‘1’ to bit 3 (offset 2). You should write b’41000 to offset 2.
    As the result, when you read offset 7, it will show b’211. b’211 indicate CONFIG_SEL_OVERWRITE and CONFIG_SEL triggers.
    Thank you.😉
