16 years ago
while loop iteration error
Hi all again!
I'm trying to use a while-loop statement in my code, but it wouldn't compile. I created a separate project to simplify the loop statement but it didn't help.
Here is the code:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity whiler is
port( clk:in std_logic;
      reset:in std_logic;
      outer:out std_logic);
end whiler;
architecture behavior of whiler is
begin
    process
        variable index : integer := 0;
    begin
        wait until rising_edge(clk);
        if (reset = '1') then
            outer <= '0';
        elsif (reset = '0') then
            while index < 6 loop
                outer <= '1';
                index := index + 1;
            end loop;
        end if;
    end process;
end behavior;
I get an error stating that the loop must end within 10k iterations, but as far as I can tell this loop should only run through 6 times, so i can't tell whats throwing this error.
Sorry if this seems a simple problem, i'm still pretty new to this language.
Thanks for your time,
Zammy
