Thanks again FvM!
My serial o/p problem is solved, but i'm still curious as to how i'd go about using a while loop, because i still can't get it to work. I've taken the while loop outside the process statement, and increment index inside. It doesn't complain about max iterations anymore but i can't work out where these errors are coming from:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity whiler is
port( clk:in std_logic;
reset:in std_logic;
outer:out std_logic);
end whiler;
architecture behavior of whiler is
variable index : integer := 0;
begin
process
begin
wait until rising_edge(clk);
if (reset = '1') then
outer <= '0';
elsif (reset = '0') then
index := (index + 1);
end if;
end process;
while index < 6 loop
outer <= '1';
end loop;
end behavior;
Error (10500): VHDL syntax error at whiler.vhd(23) near text "while"; expecting "end", or "(", or an identifier ("while" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at whiler.vhd(25) near text "loop"; expecting ";", or an identifier ("loop" is a reserved keyword), or "architecture"
