13 years ago
which part of data in ethernet frame should be passed to CRC generator?
after pass payload to CRC generator, wireshark do not receive any ethernet frame
i guess wrong, i do not know where to check, i am afraid that ethernet port in PC side drop the frame from FPGA when CRC is wrong
any other methods to see whether it send or not no matter CRC is wrong or not?
which data should be passed to CRC generators, whole ethernet frame? if so, does it include preamble?
    read document again, i change to use 125MHz , still no output and can not see any output when signal analyzer use this signal
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    entity Transmit2 is
      port (
             CLOCK_50 : IN STD_LOGIC;
                SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0);
                ENET0_TX_CLK : OUT STD_LOGIC;
                ENET0_TX_DATA : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
                ENET0_TX_EN : OUT STD_LOGIC;
                ENET0_RX_CLK : IN STD_LOGIC;
                ENET0_RX_DATA : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
                ENET0_RX_DV : IN STD_LOGIC
    end entity Transmit2;
    architecture syn of Transmit2 is
        component AlteraPLL is
        PORT
            inclk0        : IN STD_LOGIC;
            c0        : OUT STD_LOGIC ;
            c1        : OUT STD_LOGIC ;
            locked        : OUT STD_LOGIC
        end component AlteraPLL;
        component tether2 is
          port (
                ff_tx_data    : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
                    ff_tx_clk    : IN STD_LOGIC;
                    ff_tx_eop    : IN STD_LOGIC;
                    ff_tx_sop    : IN STD_LOGIC;
                    ff_tx_wren     : IN STD_LOGIC;
                    read    : IN STD_LOGIC;
                    writedata    : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
                    write    : IN STD_LOGIC;
                    clk    : IN STD_LOGIC;
                    reset    : IN STD_LOGIC;
                    --tx_clk    : IN STD_LOGIC;
                    set_10    : IN STD_LOGIC;
                    set_1000    : IN STD_LOGIC;
                    ff_tx_crc_fwd    : IN STD_LOGIC;
                    ff_tx_rdy    : OUT STD_LOGIC;
                    readdata    : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
                    ena_10    : OUT STD_LOGIC;
                    eth_mode    : OUT STD_LOGIC;
                    ff_tx_a_full    : OUT STD_LOGIC;
                    ff_tx_a_empty    : OUT STD_LOGIC;
                    magic_wakeup    : OUT STD_LOGIC;
                    m_tx_d2 : OUT STD_LOGIC_VECTOR (3 DOWNTO 0);
                    m_tx_en2 : IN STD_LOGIC;
                    rx_clk : IN STD_LOGIC;
                    m_rx_d2    : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
                    m_rx_en2    : IN STD_LOGIC
       end component tether2;
       signal clk_10     : std_logic;
       signal clk_sys    : std_logic;
       signal pll_locked : std_logic;
       signal spi_cs_n   : std_logic;
        constant whilelooptrue :STD_LOGIC := '1';
        constant enableit : STD_LOGIC := '1';
        constant disableit : STD_LOGIC := '0';
        signal set_10_external : STD_LOGIC;
        signal set_100_external : STD_LOGIC;
        constant mac: std_logic_vector(47 downto 0) := X"CB90ADD27810";
        constant preamble : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"55"; -- 8 bits * 2 = 16, 4 bits one hex
        constant SFD : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"D5"; -- 8 bits * 2 = 16
        constant dest_mac_addr1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"10";
        constant dest_mac_addr2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"78";
        constant dest_mac_addr3 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"D2";
        constant dest_mac_addr4 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"AD";
        constant dest_mac_addr5 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"90";
        constant dest_mac_addr6 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"CB";
        constant src_mac_addr1 : STD_LOGIC_VECTOR (7 DOWNTO 0)  := x"00";
        constant src_mac_addr2 : STD_LOGIC_VECTOR (7 DOWNTO 0)  := x"12";
        constant src_mac_addr3 : STD_LOGIC_VECTOR (7 DOWNTO 0)  := x"34";
        constant src_mac_addr4 : STD_LOGIC_VECTOR (7 DOWNTO 0)  := x"56";
        constant src_mac_addr5 : STD_LOGIC_VECTOR (7 DOWNTO 0)  := x"78";
        constant src_mac_addr6 : STD_LOGIC_VECTOR (7 DOWNTO 0)  := x"90";
        constant payload : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"4B";
        constant wholepacketlength1 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00";
        constant wholepacketlength2 : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"20";
        constant emptyhex : STD_LOGIC_VECTOR (7 DOWNTO 0) := x"00";
        constant emptytwobits : STD_LOGIC_VECTOR (1 DOWNTO 0) := "00";
        signal tx_data : STD_LOGIC_VECTOR(31 DOWNTO 0);
        signal macaddr_data : STD_LOGIC_VECTOR(31 DOWNTO 0);
        signal CheckSumResult : STD_LOGIC_VECTOR (31 DOWNTO 0);
        signal CheckSumValid : STD_LOGIC;
        signal startpacket : STD_LOGIC;
        signal endpacket : STD_LOGIC;
        signal ff_tx_wren_enable : STD_LOGIC;
        signal ff_tx_rdy : STD_LOGIC;
        signal ena_10 : STD_LOGIC;
        signal eth_mode : STD_LOGIC;
        signal ff_tx_a_full : STD_LOGIC;
        signal ff_tx_a_empty    : STD_LOGIC;
        signal magic_wakeup : STD_LOGIC;
        signal beginwrite : STD_LOGIC;
        signal clockOneTwoFive : STD_LOGIC;
        signal clockOneZeroZero : STD_LOGIC;
        signal clockSixSix : STD_LOGIC;
        signal clockLocked : STD_LOGIC;
    begin
            H2:AlteraPLL port map (
                inclk0 => CLOCK_50,    --: IN STD_LOGIC;
                c0    =>    clockOneTwoFive,--: OUT STD_LOGIC ;
                c1    => clockOneZeroZero,    --: OUT STD_LOGIC ;
                --c2    =>    clockSixSix, --: OUT STD_LOGIC ;
                locked =>    clockLocked--: OUT STD_LOGIC
            H1:tether2 port map (
                    -- Important connection between output pin and TSE
                    tx_clk => clockOneTwoFive,--: IN STD_LOGIC;
                    m_tx_d2 => ENET0_TX_DATA,--: OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
                    --m_tx_en2 => ENET0_TX_EN,--: OUT STD_LOGIC
                    m_tx_en2 => '1',--: OUT STD_LOGIC
                    rx_clk => ENET0_RX_CLK, --: OUT STD_LOGIC;
                    m_rx_d2 => ENET0_RX_DATA, --: IN STD_LOGIC_VECTOR(3 DOWNTO 0);
                    m_rx_en2 => ENET0_RX_DV, --: IN STD_LOGIC;
                    ff_tx_data    => tx_data,
                    ff_tx_clk    => clockOneTwoFive,
                    ff_tx_eop    => endpacket,
                    ff_tx_sop    => startpacket,
                    ff_tx_wren     => ff_tx_wren_enable,
                    read    => disableit,
                    writedata    => macaddr_data,
                    write    => beginwrite,
                    reset    => disableit,
                    --tx_clk    => clockOneTwoFive,
                    set_10    => set_10_external,
                    set_1000    => set_100_external,
                    ff_tx_crc_fwd    => enableit,
                    ff_tx_rdy => ff_tx_rdy,
                    ena_10 => ena_10,
                    eth_mode    => eth_mode, --0 = 10/100Mbps, 1 = 1000Mbps : OUT STD_LOGIC;
                    ff_tx_a_full    => ff_tx_a_full,
                    ff_tx_a_empty    => ff_tx_a_empty,
                    magic_wakeup    => magic_wakeup
        process(clockOneTwoFive)
        VARIABLE last_clk : std_logic := '0';
        VARIABLE counter : integer := 0;
        VARIABLE last_counter : integer := 0;
        begin
                ENET0_TX_CLK <= clockOneTwoFive;
                if rising_edge(clockOneTwoFive) then
                    --if SW(0) = '1' then
                    if (counter = 0) then
                        ENET0_TX_EN <= '1';
                        beginwrite <= '1';
                        ff_tx_wren_enable <= enableit;
                        macaddr_data <=mac(31 downto 0);
                        startpacket <= enableit;
                        tx_data <= dest_mac_addr1 & dest_mac_addr2 & dest_mac_addr3 & dest_mac_addr4;
                    end if;
                    if (counter = 1) then
                        macaddr_data(15 downto 0) <=mac(47 downto 32);
                        beginwrite <= '0';
                        startpacket <= disableit;
                        tx_data <= dest_mac_addr5 & dest_mac_addr6 & src_mac_addr1 & src_mac_addr2;
                    end if;
                    if (counter = 2) then
                        tx_data <= src_mac_addr3 & src_mac_addr4 & src_mac_addr5 & src_mac_addr6;
                    end if;
                    if (counter = 3) then
                        tx_data <= wholepacketlength1 & wholepacketlength2 & payload & emptyhex;
                        endpacket <= enableit;
                    end if;
                    if (counter >= 4) then
                        endpacket <= disableit;
                        ff_tx_wren_enable <= disableit;
                        beginwrite <= '0';
                        counter := 0;
                    end if;
                    last_counter := counter;
                    counter := counter + 1;
                    --else
                        --beginwrite <= '0';
                    --end if;
                    last_clk := clockOneTwoFive;
                end if;
        end process;
     end architecture syn;
    125MHz should only be used with gigabit interfaces. In your case it seems you are using MII in 100Mbit mode so you need 25MHz clocks.
    Except for that, it seems that none of the problems I've listed in post# 8 have been addressed.
    It seems that none of the problems I've listed in post# 8 have been addressed.
    i have already passed data and 25MHz clock for it to output 4 bits data,
    why there is no output data?
    As far as I know you still haven't corrected the problems I talked about, so it's not surprising you don't get any data out of the TSE. The fact that you don't enable the TSE core is the most obvious problem, but of course this doesn't mean you don't have to address the other ones too.
    could you tell me which attributes i should care ?
    as some enable are output, which attribute are enable?
    I don't understand your question.
    If you are talking about the registers to set in the TSE, I was talking about at least TX_ENA, in my post# 8.
