11 years agoWhere is "EMIF IP byte enable option"?
Hi! I have a SoC FPGA board (DE1 SoC) and did a setup using AVALON MM reading and writing 8bit from the HPS (Linux), now I wanted to extend the bit width to 128bit. When I generated the component setup in QSYS I ran into the following warning about byteenables: http://www.altera.com/support/kdb/solutions/rd07142014_810.html
Warning: System.hps.h2f_lw_axi_master/control.avalon_slave_0: control.avalon_slave_0 does not have byteenables. Writes from narrow master hps.h2f_lw_axi_master may result in data corruption.
As a fix, now I would like to turn on the "EMIF IP byte enable option" in the HPS "edit" menu. But I can't find it directly. Please, I'm still very new to FPGA and hardware development, can anybody tell me what to turn on exactly to have the "EMIF IP byte enable option" enabled and where to find it?
