11 years agoThe knowledge base article you linked to is talking about a specific problem with using the Altera DDR3 controller under some conditions.
The actual error message you posted sounds more like a problem with the custom IP that you have added in your system. If this is true, then this is an issue you will need to resolve in your _hw.tcl and .v by adding support for byteenable's.
