suganohiroki
2 years agoWhere are the initial work materials for FPGA software installation, etc.
I would like to know the links to the following FPGA-related materials and how to find them. I want to learn about FPGAs, but I couldn't find any materials on the web. I'm in a lot of trouble. ・Work...
aikeu
2 years agoHi suganohiroki,
Recommend to start with the board directly, you can use the Pre-built GSRD where you do not need build the bootloader but using pre-built booting files, you can refer to:
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD
The pre-built release update from time to time for different devices can be also found in the link below:
https://releases.rocketboards.org/
For building the the device bootloader if you require changes to the booting related files, you can refer to:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7
OpenCL is depriciated and replaced by OneAPI. For OneAPI related, you can refer to:
OneAPI system requirements:
Getting started with OneAPI:
Aik Eu
