JHaye4
7 years agoWhen using quartus_ipgenerate I get an error stating "Argument list too long" on Linux.
In the directory where my chiptop.qpf file is I'm trying to use this command specifically: "quartus_ipgenerate chiptop --generate_project_ip_files --synthesis=vhdl --clear_ip_generation_dirs". Howev...
GuaBin_N_Intel
Contributor
7 years agoI didnt see any error when tested on a design.
Info: Command: quartus_ipgenerate --generate_project_ip_files --synthesis=vhdl --clear_ip_generation_dirs top
Info: Using INI file /home/gbng/quartus.ini
Info: Found 4 IP file(s) in the project.
Info: IP file /data/gbng/test_ipgenerate/test_S10/mult_w8.ip was found in the project.
Info: IP file /data/gbng/test_ipgenerate/test_S10/multi_adder_test.ip was found in the project.
Info: IP file /data/gbng/test_ipgenerate/test_S10/ip/qsys_top/qsys_top_clock_in_0.ip was found in the project.
Info: IP file /data/gbng/test_ipgenerate/test_S10/ip/qsys_top/qsys_top_reset_in_0.ip was found in the project.
Info: Finished generating IP file(s) in the project.
Info: Previously generated synthesis files were detected in the Platform Designer IP file generation directory (/data/gbng/test_ipgenerate/test_S10/mult_w8).
Info: Skipped generation of synthesis files for the Platform Designer IP file /data/gbng/test_ipgenerate/test_S10/mult_w8.ip based on the current regeneration policy setting (Tools/Options/IP Settings).
Info: Previously generated synthesis files were detected in the Platform Designer IP file generation directory (/data/gbng/test_ipgenerate/test_S10/multi_adder_test).
Info: Skipped generation of synthesis files for the Platform Designer IP file /data/gbng/test_ipgenerate/test_S10/multi_adder_test.ip based on the current regeneration policy setting (Tools/Options/IP Settings).
Info: Previously generated synthesis files were detected in the Platform Designer IP file generation directory (/data/gbng/test_ipgenerate/test_S10/ip/qsys_top/qsys_top_clock_in_0).
Info: Skipped generation of synthesis files for the Platform Designer IP file /data/gbng/test_ipgenerate/test_S10/ip/qsys_top/qsys_top_clock_in_0.ip based on the current regeneration policy setting (Tools/Options/IP Settings).
Info: Previously generated synthesis files were detected in the Platform Designer IP file generation directory (/data/gbng/test_ipgenerate/test_S10/ip/qsys_top/qsys_top_reset_in_0).
Info: Skipped generation of synthesis files for the Platform Designer IP file /data/gbng/test_ipgenerate/test_S10/ip/qsys_top/qsys_top_reset_in_0.ip based on the current regeneration policy setting (Tools/Options/IP Settings).
Info: Quartus Prime IP Generation Tool was successful. 0 errors, 3 warnings
Info: Peak virtual memory: 947 megabytes
Info: Processing ended: Tue Apr 9 19:29:16 2019
Info: Elapsed time: 00:00:12
Could you attach the full generation message?
