LZezh's avatar
LZezh
7 years ago
when i create simulation model for ip core,Error: An unexpected error occurred during Generate: java.lang.Error: Call to quartus_sh failed unexpectedly: CreateProcess failed: No such file or directory
Info: Saving generation log to D:/Project/Quartus_Project/Data_Recorder/prj/Entity_name/Entity_name_generation.rpt
Info: Starting: Create simulation model
Info: qsys-generate D:\Project\Quartus_Project\Data_Recorder\prj\Entity_name.qsys --simulation=VERILOG --allow-mixed-language-simulation --output-directory=D:\Project\Quartus_Project\Data_Recorder\prj\Entity_name\simulation --family="MAX 10" --part=10M08SAU169C8G
Progress: Loading prj/Entity_name.qsys
Progress: Reading input file
Progress: Adding modular_adc_0 [altera_modular_adc 16.1]
Progress: Parameterizing module modular_adc_0
Progress: Building connections
Progress: Parameterizing connections
Progress: Validating
Progress: Done reading input file
Info: Entity_name: Generating Entity_name "Entity_name" for SIM_VERILOG
Info: modular_adc_0: "Entity_name" instantiated altera_modular_adc "modular_adc_0"
Info: control_internal: "modular_adc_0" instantiated altera_modular_adc_control "control_internal"
Info: Entity_name: Done "Entity_name" with 3 modules, 8 files
Info: qsys-generate succeeded.
Info: Finished: Create simulation model
Info: Starting: Create Modelsim Project.
Info: sim-script-gen --spd=D:\Project\Quartus_Project\Data_Recorder\prj\Entity_name\Entity_name.spd --output-directory=D:/Project/Quartus_Project/Data_Recorder/prj/Entity_name/simulation/ --use-relative-paths=true
Info: Doing: ip-make-simscript --spd=D:\Project\Quartus_Project\Data_Recorder\prj\Entity_name\Entity_name.spd --output-directory=D:/Project/Quartus_Project/Data_Recorder/prj/Entity_name/simulation/ --use-relative-paths=true
package "tb2" isn't loaded statically
while executing
"load "" tb2 "
  • Vicky1's avatar
    Vicky1
    This issue may occur because of Environmental variable so please refer the below solution link,
    https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd12242011_411.html
    You can set or remove certain paths from your environment variable in windows as fallows,
    1) Open Control Panel --> Systems --> Advanced system settings --> 'Advanced' Tab --> Environment variables--> Under System variables
    2) Look for Path(QUARTUS_ROOTDIR) and click 'Edit'
    3) Either set it correct version or remove
    please let me know how it works for you.
    Vicky
    • LZezh's avatar
      LZezh
      Very thank you,but I have been tried your solution,it didn't work.
    • LZezh's avatar
      LZezh
      When I generate ip without creating simulation model,it works fine.but when generate file for simulation, it went wrong.ip-setup-simulation and ip-make-simscript got wrong.
    • ishikawa's avatar
      ishikawa
      I had the same problem with mine. I opened the environment variable settings from the control panel and checked the quartus_rootdir and found C:\intelFPGA_lite\17.1\quartus. I don't know how to edit it.
      (i use quartus prime lite17.1)
  • Vicky1's avatar
    Vicky1
    Could you provide project file for replication(Project-> Archive Project)?
    Vicky
  • Vicky1's avatar
    Vicky1
    Have you resolved the issue?
    Should I consider that case to be closed?
    Vicky
