when i create simulation model for ip core,Error: An unexpected error occurred during Generate: java.lang.Error: Call to quartus_sh failed unexpectedly: CreateProcess failed: No such file or directory
This issue may occur because of Environmental variable so please refer the below solution link,
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd12242011_411.html
You can set or remove certain paths from your environment variable in windows as fallows,
1) Open Control Panel --> Systems --> Advanced system settings --> 'Advanced' Tab --> Environment variables--> Under System variables
2) Look for Path(QUARTUS_ROOTDIR) and click 'Edit'
3) Either set it correct version or remove
please let me know how it works for you.
Vicky
When I generate ip without creating simulation model,it works fine.but when generate file for simulation, it went wrong.ip-setup-simulation and ip-make-simscript got wrong.
