LZezh
7 years agowhen i create simulation model for ip core,Error: An unexpected error occurred during Generate: java.lang.Error: Call to quartus_sh failed unexpectedly: CreateProcess failed: No such file or directory
Info: Saving generation log to D:/Project/Quartus_Project/Data_Recorder/prj/Entity_name/Entity_name_generation.rpt Info: Starting: Create simulation model Info: qsys-generate D:\Project\Quartus_Pro...
Vicky1
7 years agoHi,
This issue may occur because of Environmental variable so please refer the below solution link,
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd12242011_411.html
You can set or remove certain paths from your environment variable in windows as fallows,
1) Open Control Panel --> Systems --> Advanced system settings --> 'Advanced' Tab --> Environment variables--> Under System variables
2) Look for Path(QUARTUS_ROOTDIR) and click 'Edit'
3) Either set it correct version or remove
please let me know how it works for you.
Vicky
LZezh
7 years agoVery thank you,but I have been tried your solution,it didn't work.
