16 years agoposedge means the transition from 0 to 1
negedge the oposit transition from 1 to 0 usualy a clock is used as posedge, so everytime your clock signals goes from 0 to 1 using posedge or negedge for the reset condition depends on the logic level you use or your design if you reset signal is negativ logic meaning a 0 is reset and 1 is normal running mode, then you want to reset your logic as soon as the reset condition is valid. that is true as soon as your negativ reset leaves the 1 condition. so you use negedge reset (1->0) also it is important to notice that any signal beside your clock in the always content is treated asyncronously. if you would write always @ ( posedge clk ) if ( reset ) // reset else // normal mode then your reset is a syncrounous reset and the reset condition is checked with the next clock cycle if you write always @ ( posedge clk or posedge reset ) if ( reset ) // reset else // normal mode then your reset is executed as soon as this condition occurs regardless how your clock signal is. this is a asyncroun reset
