10 years agoWhat's the Altera Equivalent to the Xilinx STARTUP Primitive GSR/GlobalSetReset?
Here's an example of what it looks like for Xilinx: // Instantiating STARTUP symbol STARTUP U1 (.GSR(global_reset)); always @(posedge clk or posedge global_reset) begin if (global_reset) begin dff <= 1'b0; end else begin dff <= xyz; end end Ok...Altera how to do it without needing a clock and initial conditions to create a global reset? The reason why I ask is because I have a QSYS with an HPS core that is outputing a clock from a pll and the top-level FPGA doesn't have a Clock or reset pin that is accessable to the FPGA logic...1 Reply
To answer your main question - there is no Altera equivalent to the GSR primitive.
You should be able to route the clock and a reset signal from the HPS to the FPGA fabric directly. What problem are you having? Export the signals in Qsys and then in the top-level HDL wrapper (I assume) that instantiates your Qsys module and your FPGA module just wire the clock and reset from the Qsys module to the FPGA module.
