18 years agoThank you. Finally I wrote as below:
module edge_detection(a,b,c,clr,out); input a,b,c,clr; output out; wire pos_clock,neg_clock; assign pos_clock=a^b^c; assign neg_clock=!(a^b^c); reg out0, out1; DFFT DFF0(1,out0,pos_clock,clr); DFFT DFF1(1,out1,neg_clock,clr); assign out=out0|out1; endmodule module DFFT(q,d,clock,reset); input q,clock,reset; output reg d; always @(posedge clock or posedge reset) if(reset) d<=0'b0; else d<=q; endmodule But I am curious about the constraint you mentioned, that ignoring of "out". I can't find it in the IEEE Std 1364-2001 file. Can you give me an instruction about where or which page I can get it? I want to know more about it.
