12 years ago
what should i replace with question mark?
hi every body
this is my code
architecture structure of main is
begin
    L1:for s in 0  to N-1 generate
        L2:for t in 0 to 2**s-1 generate
            -- Output index
            constant output_index : integer := (2**s-1) + t;
            -- Input indices (based on the output index)
            constant input_index_start  : integer := 2*output_index+1 ;
            constant input_index_end    : integer := 2*output_index + 2;
            begin
            DUT: entity work.trans
            port map (
                rstN => rstN,
                clk  => clk,
                data => n(input_index_end downto  input_index_start),
                i    => n(output_index),
                d     => m(output_index)
        Avrg(???????????)<=m(output_index);
        end generate;
    end generate;
m is the output of my for-generate statement.
i wanna save the value of m in Avrg , every loop .
i mean in the first loop i want to save m in the LSB of Avrg(0)
in the second , save it in Avrg(1)
etc.
    you are confusing yourself because you have nested for loops. I think you want to put Avrg in the outer loop?
